Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Miele W1512 not performing complete cycles
- This topic has 6 replies, 2 voices, and was last updated 13 years, 2 months ago by
n9eav.
January 22, 2013 at 10:37 am #73690
n9eav
ParticipantI have a Miele W1512, purchased in 2006. Excellent build quality, but this week the programs have started to misbehave.
For example: Cottons wash fine and then during rinses the pump stays activated for 3-4 minutes, the digital timer clock does not move and then it jumps from say 40 mins to 52 mins. It eventually completes the cycle much longer than normal, but does not finish with a fast spin. Most other programs are similar, a rinse missed, or spin not completed. The pump does also run far longer than it should. No fault light or codes however. I have cleaned the filter and water pipes that i can reach.
It it electronic? or is some part confusing the computer?January 22, 2013 at 8:16 pm #388429Seamy
ParticipantRe: Miele W1512 not performing complete cycles
It may be as you say “is some part confusing the computer?”
I doubt very much if there is a “computer” in the machine even though you paid a lot for it, it is however controlled by an electronic circuit board like most modern machines. Perhaps whats confusing the electronic is the pressure vessel is clogged with crud, which prevents the electronics getting the message that the appliance has emptied. It needs to be cleaned out. Your local appliance engineer should be able to do this.January 23, 2013 at 8:14 am #388430n9eav
What and where is the pressure vessel please?
January 25, 2013 at 9:21 pm #388431Seamy
[quote=”Seamy”. Your local appliance engineer should be able to do this.
Pressure vessel is connected to front of tub..February 2, 2013 at 10:35 am #388432n9eav
My local appliance engineer won’t touch it, say’s it’s a Miele
February 2, 2013 at 1:11 pm #388433Seamy
Thats his loss, they are best engineered product on the market & quite straightforward to repair for any with a basic understanding of appliances.
Miele will look at it but will charge you considerably for the privilege.February 3, 2013 at 5:55 am #388434n9eav
Don’t I know it, that’s why I am here! I can do things, I just can’t figure out how to get at the parts as the panels don’t seem to come off as easy as some…
