Morning Guys,
Does anyone know if the door gasket can be changed with the machine in situ, as I have a customer with a stacked machine in a tiny cupboard and it is going to be a nightmare to get out. Many Thanks Neil
Sorry to say that you need the worktop off washing machine, remove detergent drawer, unclip facia panel, remove two trox screws at top of front panel, remove two trox screws holding door interlock, remove wire band from around door seal, unclip font of door seal, THEN the front panel will lift off so you can get at door seal fixing.
Thanks that’s what I sort of thought it would be looking at the exploded diagram, Ho Hum the customer will have to pay for two engineers. Thanks again Neil
