Check drain light coming on and sometimes excess detergent light.
Pumping out ok (on the occasions when this could be verified) and there was no detergent in the machine when the excess detergent light came on.
Sometimes starts to fill and then just agitates. Mostly doesn’t fill at all.
No water in the base, pressure hose not holed or blocked. Machine is shoe-horned into a tiny utility so access was v difficult. In particular, the machine could not be worked on from above without some built in cupboards being removed.
Any clues folks?
Dez
