Soon as machine turned on Drain & Inlet lights flash together.If any prog is selected,prog aborts/pump cys in.
Suspect this is an error code,meaning???!
So the water protection system has activated.The manual advices calling service dept! Is there anything I can do about this?
Is it an anti flood abort mode,requiring presure bowl to be unblocked or pr. switch prob?
