Been asked to change the door gasket..I have changed Miele door gaskets on a few, the ones with a bolt under door…but never on a integrated one..I expect they are different to remove the front to access the drum…any advice would be welcome..cheers John
There isn’t a lot of difference,. Pop the caps off the plastic lower panel screw covers, 2 tor’s 20#, pop the plastic panel down, then 2 torx20 at the bottom of the front panel, door switch screws and the single tor’s in the middle..
easy Peary:)
I do find though that removing the decor door first makes life a lot easier
