Water intake very slow.
Water pressure ok.
Inlet hose disconnected from 3 way valve,flows slowly from hose.
Hose/valve replaced,still slow?
When another machine is connected,that fills fine?
Hi Paul
I think from memory this is related to a blockage in the small grey pipe that runs down from the soap box, just heard the voicemail you left me,but am on my way to a funeral this morning so won’t have time to ring you…
But check all breather pipes first and see if that helps.
Been having a rethink on this one today,now thinking the valves are not getting the full mains voltage,and are maybe not opening fully? Not sure what you mean when you say works fine when connected to another machine!
