Miele W3444 knocking during spin
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Miele W3444 knocking during spin
  • #95083
    stu-stu-stu
    I have a 12 year old Miele W3444 washing machine which has suddenly developed a knocking noise during the high spin. Any suggestions?
    Stu
    #459329
    does it knock with no washing in ?
    stu-stu-stu
    Thanks for your reply. I’ll give it a go. I’ve got the motor out at the moment to check the brushes (they look fine considering the age). Could do with knowing how to run the spin without putting the front back on and choosing a drain & spin programme. Not sure how to work the service mode though.
    Stu
    #459331
    miele are very secretive so getting tech info is hard
    as far as i am concerned it boils down to 2 possibles drum problems or shock absorbers
    well that’s serious
    sounds like a drum spider failure and if it is then its beyond economical repair
    stu-stu-stu
    You mean the big solid metal wheel at the back, driven by the belt? If so, what could be wrong with it? It looks ok from what I can see.
    Stu
    #459334
    stu-stu-stu wrote:You mean the big solid metal wheel at the back, driven by the belt? If so, what could be wrong with it? It looks ok from what I can see.
    Stu
    no the drum spider is bolted to the back of the drum and carries the weight if the washing
    this is the same part from an old hotpoint machine
    https://shop.ukwhitegoods.co.uk/hp0525-hotpoint-more-washer-drum-support-bearing-kit
    stu-stu-stu
    Ah, I see. Is it possible to get hold of the Miele part? If it was reasonable money I’d potentially give it a go if the machine is scrap anyway.
    Cheers for your help with this, it’s much appreciated.
    Stu
    #459336
    had one recently and when I got a price from Miele it was a kit of some kind. cant remember exact price but over £200 for certain
    stu-stu-stu
    https://drive.google.com/file/d/1aJL5kOucH6R9QlDOOTs-WneNmUksxkUw/view?usp=sharing
    Yep, I’d say that’s gone! Good call Dave, you were right!
    Stu
    #459338
    In polite forum language
    “yep that’s Broke” ( with a capital F )
