Miele W360 wps Novotronic
Home Forums General Trade Forum Miele W360 wps Novotronic
  • #80790
    Ashby
    When this machine is switched on it will go into a short spin and then stop.
    The rinse indicator light flashes and in the programme sequence display “- – – ” appears in the display?
    I’ve checked the carbons and they are fine cant find any broken/loose wiring.
    Anyone familiar with Miele that could help please?
    Many thanks.
    Ashby
    #414336
    Re: Miele W360 wps Novotronic
    You should post technical questions in the correct forum (Trade Technical) 😉
    #414337
    philfish
    Rinse light means that the board (pcb or as miele like to call it ” the electronic”) as not received a signal (voltage) from the tacho on the motor, so if you have metered the motor out correctly and checked the carbons,tacho,windings etc then I am afraid the next step you will be looking at will be the board………sit down and brace yourself when they give you the price, not cheap!
    Oh just for future refernce if I am usually metering the motor or any other component on a miele I tend to do it from the board itself, A, you meter the loom and the component and B, it is usually easier to get at then anything else on the machine! It is easy to understand which component goes to where because they have a wiring diagram come with them.
    Martin is right though this should be in technical.
    Phil
    #414338
    clayside
    Would start with tacho coil on motor, have had a few open circuit. Clayside
