miele W3722 GB
  • #49222
    kevinlewis
    Showing Technical fault F53. Changed the Motor module “Brush assembly” and the power board 06862013. Exactly the same fault.
    I tried it on spin. It starts spinning for about one minute then F 53 shows. Can’t see any loose connections.
    #299191
    washermanuk
    Re: miele W3722 GB
    Speed sensor fault
    #299192
    twinspark
    Re: miele W3722 GB
    check every wire back to board the do break i have had this myself 🙂
    #299193
    gegsy
    Re: miele W3722 GB
    Moved to trade Kevin 😀
    washermanuk
    Re: miele W3722 GB
    I looked into this not sure if this might be a problem? Depending on serial number ie: upto 40/ and from 41/ etc, the module and brush holder tacho assembly are different they need to match not sure if you got em via Miele and gave serial numbers? This machine is only 2yrs old is it still under a warranty?
