Hi Guys, A little help with this one please. The fault is that the machine goes straight into spin when the motor starts either in wash or spin, it then errors with three lines in the display. In your experience is this usually caused by the PCB or the motor? Thanks in advance
you will have to check both but first check the motor. its prob unlikely to be an open circuit coil so suspect magnet broken. if that ok check pcb Triac
