MIELE W404
  • #62821
    MDE
    Hi all, Odd one this,I fitted brushes to this washing machine last week and on testing it afterwards it looks like its not taking in enough water, When I put it on it takes water in for 10 seconds,pauses, and then 8 seconds but the water level is below the drum. There is a button to increase the water level and when you push it the level looks about right.The bottle is not blocked and the valve is ok,Pressure switch is a part of the control board. Any thoughts on this would be appreciated.
    Thanks Mark.
    #351412
    Seamy
    Re: MIELE W404
    Some of these have load sensors on the suspension leg, it should take in more water if it senses a bigger load, the water level sensor/pressure switch and this load sesor can be recallibrated if needed, maybe some of the Miele engineers will post details.
    #351413
    MDE
    Re: MIELE W404
    Thanks Seamy, I went back to try a bigger load on this but it made no difference, they are using it with the high water level buttin on at the moment.
    Thanks Mark.
