Miele W435 Plus WPS – extending inlet/ drain hoses
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Miele W435 Plus WPS – extending inlet/ drain hoses
  • #93001
    ShivaYash
    Dear all,
    I’ve just moved to Berlin, leaving behind my trusty W919WPS in my flat.
    However I’m pretty happy with the W435Plus I picked up from a local dealer for 230 euro, delivered. I am trying to find an English language manual for this machine, and also to try and understand if its a high spec model, it seems to be to me, having the newer honeycomb drum and a 1500 spin. It also have the sloped control unit, which I think is nicer as well, and more ergonomic.
    But the real question I have is inlet and drain extension. In Germany most washing machines tend to live in the bathroom. Our bathroom is a good size but to avoid block the window, it means placing them further away that the current hoses allow. Miele DE are quoting me 126 euro for part number 6390850, and say that a standard (generic) set of hoses and clips will not work with the WPS. Is this true?
    Has anyone experience of this part, and its fitment?
    With best wishes and greetings from a cold but sunny Berlin.
    Dr Shiva Yash
    #452853
    don
    Re: Miele W435 Plus WPS – extending inlet/ drain hoses
    You can download a copy of the instructions here from the German Miele website.
    As for the extension hoses they look pretty normal to me with no water proof electric feed going through them. I would have thought a generic set would do the trick. However if you want the rela thing they are cheaper from Europart in Holland this link will take you to them.
    Don
    #452854
    ShivaYash
    Thanks Don. I found the original part on eBay for €81. To keep the machine waterproof safe a double core hose is required. I priced up a similar metal braided hose and it wasn’t far off, plus it’s nice to keep it all original and save with fitting issues. The set works a treat I must say. Ps. I wanted English instructions and have something similar but not exact on the U.K. site. I think this machine was not sold in the U.K. in the format I have.
    Now I need to understand how to refit the stacking kit. No instructions either. I have the universal Miele kit, the one without shelf.
    #452855
    don
    Stacking kit installation instructions are usually found in the tumble dryer manual.
    Don
    #452856
    ShivaYash
    No luck in my tumbler dryer manual. I have the T4422c.
    #452857
    don
    There are quite a few You Tube tutorials for Miele stacking kit fitting. There must be one which could help.
    Don
    #452858
    ShivaYash
    No help sadly… already checked before posting on here.
