Miele W460
  • #58980
    geoff1
    I have a Miele W460 tolook at tomorrow and I have limited knowledge of the Miele products.
    The check water inlet light comes on but machine does fill with water and will not stop and till switched off. Ok on drain and spin.
    Besides the pressure switch hose being blocked or split do these machines have other faults to cause this. Also is there a test programme for this machine.
    Any help appricated
    Geoff
    #336372
    Seamy
    Re: Miele W460
    Did one yesterday with same symptoms, pressure vessel blockages are a common problem.
    #336373
    geoff1
    Re: Miele W460
    Thanks for reply.
    Found pressure hose between chamber and front control panel had rubbed on plastic wiring channel.
    New pipe and re routed – job done
    Geoff
