Hi all
Our Miele W460s wahing machine has developed quite a leak from the door and although the gasket looks to be undamaged I’m hoping a straight replacement will fix the issue.
I’ve had a go at opening the front but can’t seem to work out the complete process. I’ve removed the screw in the detegrent draw, the bolt at the bottom of the door opening and a screw at the bottom left of the machine behind the kick plate. This seems to free up the bottom left of the machine but the top left still seems pretty solid but there are no other obvious fixings holding it in place. I’m assuming the front swings open and is hinged on the right hand side ?
Has anyone got any experience with this model and could advise on what else I need to do?
Many Thanks
Jim
