Hi, I wondering if anyone else has come across this problem. 30ma rcd circuit trips instantly as soon as I put machine on any hot wash cycle. Works fine in cold rinse/drain cycle.
I first assumed the heater element, but when I tested it is was fine around 24-25 ohms. Did 500v insulation test on each terminal of the element to earth which was clear.
No sign of internal leaks all very dry inside.
I also tried plugging in to a different circuit with same results.
I am now going to have a further look for any chamfering of cables.
Any ideas would be appreciated
thanks
