Miele W487WPS W/M problem
  • #66405
    jontymox
    Good evening all,
    Has anyone come across both the “check inlet and check drain”
    lights flashing in unison on the above m/c?
    This occurs only 2 or 3 times per month on a customers’ m/c and refers to “waterproof system has activated.”
    I have inspected the m/c for leaks, which aren’t evident, and wonder if there is a faulty sensor causing the problem.
    If so, I wonder where this sensor is located in order for me to test it, or if there is another cause.
    Best wishes,
    jontymox
    #364100
    Seamy
    Re: Miele W487WPS W/M problem
    Water in base most likely the culprit, can also be gunged up pressure vessel.
    #364101
    A likely reason for water in base is door seal dribbling due to one or other of the usual reasons. On these new Mieles it seems to be directed into the collector pan.
    Mike.
