Miele W489 I WPS Washing MAchine Spin as soon as switched on
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele W489 I WPS Washing MAchine Spin as soon as switched on
  • #86556
    Twoten
    I have received a call on the above Miele.
    When the on button is pressed the machine bursts into spin for a couple of seconds then the rinse light flashes. It doesn’t matter if a wash is selected or not and the start button is not pressed.
    Does anyone confirm if this is likely to be the PCB throwing the machine straight into spin.
    Thanks.
    #432141
    Re: Miele W489 I WPS Washing MAchine Spin as soon as switche
    sound very likely
    dave
    #432142
    philfish
    I would check motor and tacho first. Rinse light usually means no signal from tacho.
    Phil
    #432143
    Twoten
    philfish wrote:I would check motor and tacho first. Rinse light usually means no signal from tacho.
    Phil
    I thought the rinse light only shows up a fault when the motor attempts to turn during the cycle. Why would it kick into a spin when first powered up? If the tacho was O/C would the motor run before a program is set?
    #432144
    philfish
    Sorry didn’t realise it was as soon as it is powered up, in the case I would look towards the board.
    Phil
