Miele W504 spinning full speed
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele W504 spinning full speed
  • #52182
    Seamy
    Been to look at a Miele W504 which goes direct to full speed on spin & wash. Checked motor tacho, reads ok, looks ok, leads on motor look o.k. Suspecting main board, anyone know part number & price please.
    #310879
    Re: Miele W504 spinning full speed
    before you scrap main board look for motor triac and see if it is short circuit
    or ring EMW and see if they will look for you be a lot cheaper for this and more profitable as you can charge extra money for board repair
    When you say you read the motor tacho, I expect you just metered it in ohms?
    It’s a good idea to check for an output by attaching your leads to the terminals and monitoring the voltage as you turn the drum. (I can’t remember if you’re looking for ac or dc, the first I think, but try both.) It should rise as you turn faster. That way you’re checking the magnet and the coil. Better still would be to monitor it at board end of lead.
    Mike.
    #310881
    washermanuk
    Hi Matey need serial number for part!
    if you need to order a new board it will cost £319. 😯
    motor is covered by a 10 year guarantee but Miele will have to call and fit that :rolls:
    #310882
    clayside
    Think only brushless motors have 10 year g/tee
    clayside
    #310883
    Seamy
    Yeah i tested the tacho by turning the drum. Ser’# 67956868. Gave her a quote for replacing board, when she came around after collapsing she got in touch wuth manufacturers. Think shes been talked into taking out an insurance which will cover cost of this repair & subseqent ones.
