Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › miele w504 – start any programme and then rinse flashes
- This topic has 7 replies, 3 voices, and was last updated 14 years, 8 months ago by
gandh1.
August 9, 2011 at 8:05 pm #64419
gandh1
Participantleak evidence in the base, but f/c/d seems to be in “dry” mode.
been thru drainage system with a fine tooth comb, but cant get any result, can anyone give any helpful pointers? due to go back to it later this week, and cant really write it off as that wont please the g/f’s parents muchly :/ plus obviously dont really fancy the ignomy of telling them im stuck and they need miele, if i can really help it 😉
Ta!
August 9, 2011 at 8:21 pm #357039gandh1
ParticipantRe: miele w504 – start any programme and then rinse flashes
i see on tintergooglenetweb it reckons its motor issues, if this is correct then it had new brushes about 6 months ago, so wont be them being low, and that leaves the tacho, never had to check one before, so how do you check the tachos on these?
September 4, 2011 at 4:24 am #357040gandh1
help pls! this is gathering dust whilst my loan machine is slowly being broken :'(
September 4, 2011 at 6:46 am #357041eastlmark
ModeratorRe: miele w504 – start any programme and then rinse flashes
IME tacho’s rarely fail, would just check for continuity from the plug on the module. Could be the module relay/fuse issue discussed recently.
September 4, 2011 at 8:44 pm #357042gandh1
i knew if id call your name youd come a running 🙂 cheers mark
December 1, 2011 at 11:01 pm #357043leavemetogetonwithit
Ghand1, Did youget anywhere with this as I have same problem at the moment.
Mike.December 29, 2011 at 10:33 pm #357044gandh1
funny you should mention this, its actually still in the workshop lol. we got so busy lately i forgot all about customer until she came in monday to find out more as shes broken our loan machine! after much red facedness on both sides, i said id try and sort it out now its not so hectic. oddly enough found a scrap miele w360 at the back of a container we were clearing out as were giving it up this week and hoping its got the same motor on it as i know that one failed due to bearings. Any luck your end ?
December 29, 2011 at 10:44 pm #357045leavemetogetonwithit
gandh1 wrote: Any luck your end ?
