Miele W522P
  • #66215
    ChrisR
    Hi guys.
    Got to change a door seal on one of these but can`t see how to release bezel so as to remove front panal for access.
    All suggestions gratfully received
    Best wishes
    Chris
    #363487
    steve1
    Re: Miele W522P
    HI CHRIS
    if i remember right , remove soap draw then remove screws in facia ,you will see them when you take out the soap draw, open port hole door remove bolt, remove screws at bottem of front panel, then front panel swings open, to gain access to the door gasket
    cheers
    steve (im just round the corner from you)
    #363488
    ChrisR
    Re: Miele W522P
    Hiya steve
    I know what you mean but this isn’t the same
    The panel doesn’t appear to hinge right to left
    It looks as though it slides out like a Bosch
    But I can’t see how to release it from the top.
    Children’s Society job this so if anybody has an answer I’d be
    grateful
    Thanks Steve
    #363489
    ChrisR
    Re: Miele W522P
    Help somebody
    I’m going back tomoz
    #363490
    clayside
    Re: Miele W522P
    Remove kickplate/plinth either by two capped screws or if later model it just pulls off. Remove two torx screws holding door lock , remove door seal band and release door seal from front panel,at six o’clock position onder door remove either 10 mm bolt or large torx screw, under front panel where plinth came off their are four small torx screws, two on left hand side and two on right, remove the outer one on each side only. Then front panel should pull away at bottom and then downwards and off.
    Hope this makes sense. clayside
    #363491
    ChrisR
    Re: Miele W522P
    Thanks clayside
    I`ll let you know
    #363492
    ChrisR
    Re: Miele W522P
    Thanks clayside
    Bang on
    I can only use product ignorance as a excuse
    #363493
    clayside
    Re: Miele W522P
    Glad to help. Clayside
