On switch on the pump starts to run continuously. If I set it to a programme, on pressing the start button the machine begins to fill, and the pump continues to run, but that is all it will do. I have checked the base for water and a sticky float, but all is ok. Any ideas please? I suspect this is a module fault, but am happy to be proved wrong. Any help gratefully accepted :-). Thank you. Steve.
