Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Miele w524 Prestige plus tripping rcd
- This topic has 6 replies, 2 voices, and was last updated 3 years ago by
pandrews.
March 25, 2023 at 1:45 pm #101831
pandrews
ParticipantHi
When the washing machine is on and filling up with water, a little while later, the rcd trips.
If its on a drain / spin program, it works without any issues.
There’s no obvious leaks from what I can see with the top cover removed.
I did also try to select the cold program, and a little while later, it also trips the rcd.
This leads me to think perhaps the heating elements need replacing. But before i do this, can someone advise me where this part is?
Which cover of the washing machine should I remove to access? I have multimeter, and if someone can also advise what the reading should be if it’s defective?
P.
March 25, 2023 at 3:10 pm #486364pandrews
ParticipantOk found the heating element which was accessible by removing the front cover.
Took reading
Heating element: 23.6
Heating sensor: 16.17 kAny advice regarding the above readings?
March 25, 2023 at 3:52 pm #486365electrofix
Moderatorits the reading to earth that matters
should be millions of ohms
DaveMarch 25, 2023 at 4:03 pm #486366pandrews
Participantelectrofix wrote:its the reading to earth that matters
DaveHi Dave, thanks for the info.
Have checked the heating elements to earth: 2.1M ohms
What does this reading indicate? If it’s defective, would this cause the rcd to trip?
Thx
P.
March 25, 2023 at 4:17 pm #486367electrofix
Moderator2.1 is not bad
the 2 most likely parts to cause this are motor or heater
as a quick test, disconnect the main heater wires and try the machine to see if it trips
DaveMarch 25, 2023 at 4:38 pm #486368pandrews
Participantelectrofix wrote:2.1 is not bad
DaveInteresting, I did what you advised – it’s not tripping.
Previously, as soon the water is filled I.e. prior to the heat up, it would trip.
Time to replace the heater? Where can I find the part number from?
March 25, 2023 at 4:46 pm #486369electrofix
Moderator -
