miele w526
  • #73703
    HotDog
    Not been to this yet but customer says rinse light starts to flash shortly after starting to wash looked in known error codes but no match anyone have any ideas on this
    #388530
    Seamy
    Re: miele w526
    Rinse led flashing indicates no motor action. Check brushes.
    #388531
    HotDog
    Re: miele w526
    Yes thanks for that i did find it after the post sounds like you have to remove the front panel to access the motor
    #388532
    Muv
    Re: miele w526
    If its not the brushes… Its board out time and replace a few components..ive done around 10 of them in the last 2 months…
    If you want you can send me the board?
    Muv
    Re: miele w526
    As long as its fitted with the EL200 board of course!
    #388534
    Muv
    Re: miele w526
    Just checked ..its fitted with the EDPL122 board… Sorry dont repair those…yet!
    Seamy
    Re: miele w526
    Rinse led flashing means no motor action, i’d start by checking the motor brushes, back plate that houses brushes comes off motor.
    If the motor is o.k & loom/connections are o.k then i’d think about getting a p.c.b.
    There should be a schematic diagram in all Miele appliances that will allow you to check/trace cabling from p.c.b to motor.
