Re: Miele W5298WPS
Hi Dave, thanks for reply. There is a low voltage supply to the board, and a small red LED on the main board confirms that when you power up. There’s a large power relay after the mains filter, that the low voltage supply presumably feeds back into from the main board to power up a coil and switch mains voltage to the rest of the machine. I have no low voltage supply to that relay, although the mains power is feeding into it ready to be relayed! Hope that makes sense to someone… anyone 😥
