miele W562 stops excess detergent light flashig
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries miele W562 stops excess detergent light flashig
  • #73863
    mike100
    Intermittant fault in that it stops near end of cycle with excess detergent light flashing. Open door and clothes are sopping wet. Change to spin only and it works fine.
    Have checked pump and anti flood float, both ok.
    Any ideas please.
    Thanks,
    Mike
    #389113
    Muv
    Re: miele W562 stops excess detergent light flashig
    According to the user manual, its bot a fault as such..customer is just using to much detergent!
    Seamy
    High level 140mm still detected, likely the pressure vessel is clogged or appliance is not getting rid of water in time, if for instance appliance went to spin before all water was out this would pressurise pressure vessel & pressure switch & F5 excess detergent fault code would be generated.
    Take a look at the drainage manifold (running up inside at back) check for blockages.
