Has anyone come across a heater change on this model? Is it straight forward? It looks as if the heater is fitted from the inside, as the heater plate is flush with the frot plate. Can anyone help please? Cheers. Steve.
Very straightforward to change the heater on a Miele, theres a bracket pushed onto the grommet that holds it in place. Everything pulls out from the front. Be careful that you put in the correct element as they are available in different wattages & voltages.
