Miele W806
  • #68212
    rocker
    there is water leaking from the pump filter drain tube, have cleaned housing & filter..on refit still leaks / tightened with grips still small drips..have the same fault on another miele same pump housing fitted as any one else come accross this problem please. John
    #370199
    Re: Miele W806
    Filters on Miele are a big weak spot. there is I think a seal kit for this which comes with some white grease to lube the seals. Assuming no one has been digging around in there and damaged the face of the housing, it can only be the seals.
    #370200
    rocker
    Re: Miele W806
    Thanks eastlmark will look into that. John
