MIELE W820 Bearings
  • #40435
    MDE
    Hi all, I had a look at this washing machine and the bearings are gone,and the inner drum has dropped a little, I have never replaced bearings on one of these machines before so I have a couple of questions I hope someone can help me with.
    1. Is it likely the shaft on the drum will need to be replaced?
    2. Do the bearings come as a kit or can I buy the seal on its own and get the bearings elsewhere. [cheaper] Connect show bearing kit £132. Retail.
    3.Is the heating element likely to have been damaged by the drum dropping?
    4.Do I need to take the outer drum out to take the bearing housing off the back to fit the new bearings.
    Thanks Mark.
    #266332
    Seamy
    Re: MIELE W820 Bearings
    Not too often you’ll have to do a bearing job on a Miele is the good news. They are made of sturdy stuff.
    I take the cross-piece off the back, knock out bearings & seal, replace both bearings & seals. Not overly difficut to do really.
    There is a sleeve/piece that can be taken off shaft & replaced if its damaged which should come with the bearing & seal kit, you may find its not damaged & in that case i’d leave it on if it looks good.
    Check heater for damage, it could be about £60 or something rediculous like that if its damaged.
    #266333
    clayside
    Hi Mark,
    Drum shaft not normally worn if machine hasn’t been used to long with bearings gone.
    Kit comes with seals etc. When I tried to buy seal and bearings from different suppliers it worked uot more.
    Element not normally hit
    Yes suds container out job.
    Regards clayside
    #266334
    MDE
    Seamy & Clayside thanks for the replies, with that info in mind I will carry out the repair, it will be nice to do something different for a change
    Mark.
