Miele W821 W/M Rinse Hold error code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele W821 W/M Rinse Hold error code
  • #62158
    Poppins
    This machine is flashing the rinse hold light when it is about to spin.
    Does anyone know what code it is?
    Many thanks
    Chris
    #348961
    Seamy
    Re: Miele W821 W/M Rinse Hold error code
    Rinse l.e.d flashing denotes drive failure, check the usual, carbon brushes, cable connection to motor etc.
    #348962
    Poppins
    Thanks for that Seamy.
    It must be cable then as it doesn’t always have a problem spinning although I will check the brushes as a matter of course anyway.
    Do you know if it can be affected by the door interlock as I suspect there is a problem there as it doesn’t always engage when trying to close the door and consequently the ON light doesn’t come on? I was wondering if this could be happening in the cycle. I few flicks of the catch seems to do the trick when it plays up.
    #348963
    Seamy
    door may just need a smear of grease on latch/catch, just check that door pull cord that goes down to filter door isn’t catching on anything as this can cause fault described
    #348964
    Poppins
    Thanks again Seamy.
    Do you know if Miele carbon brushes are easy to get hold of? I haven’t been able to find any type on Connect, Qualtex or Europarts.
    #348965
    don
    Carbon brushes 4297412.
    Listed on Connect but special order only, part number not recognised by Qualtex I’m afraid 🙁
    Don
    #348966
    Poppins
    Thanks Don
    #348967
    Poppins
    Don, is this the part number for the brushes for this specific Miele model or is it the same across them all? I havn’t seen many!! 🙁
    Chris
