Miele W827
  • #47997
    timdowning
    Don’t normally look at Miele…in for a penny.
    Machines leaking every wash and two weeks ago the check inlet / filter light came on.
    The light has only come on once.
    Not wanting to look a fool, i was wondering how to get the front off one of these, or if theres any data I can be sent?
    Heres hoping!
    Tim.
    #295251
    suedehead1
    Re: Miele W827
    remove a couple of screws at the bottom behind the kickplate and 1 or 3 bolts round the outside of the door seal, remove outer lip of seal and cuple of screws in the door lock and the front opens up on a hinge at the right hand side,
    if its leaking there is a float in the bottom it could be the door seal or the filter not in tight enough.
    (from memory)
    #295252
    keithwilliams
    Re: Miele W827
    when you open the front panel you’ll see a gasket around the front edge of the soap box housing. i’ve had at least four where there has been a slight leak from here. if it is this then pipe in a thin bead of silicon in the groove and refit the seal. when you reattach the front panel it”ll be o.k.
    #295253
    timdowning
    Re: Miele W827
    Cheers
