Miele W827
  • #49208
    S1MON
    Rinse light flashing, have replaced brushes but still fault remains. I belled out the motor and was satisifed with that, but don’t want to change the EL200d pcb if I’ve missed something. Would i be able too just replace the White tacho housing? Or do people replace the complete motor
    cheers
    #299122
    washermanuk
    Re: Miele W827
    Brush housing is available,sounds like the pcb board tho!!! :rolls:
    #299123
    russell555
    Re: Miele W827
    dumb question…. did you pop the brushes back onto the armature???.. might be worth continuity checking the wires from the board to the motor
    #299124
    S1MON
    yer checked continuity from the schemtic from the board loom, and from the motor itself
    do they have a change micro fuse on these boards or is it a complete pcb? EL200D, anyone got the part number for the pcb and the brush housing
    cheers
    #299125
    washermanuk
    Re: Miele W827
    Can check for part numbers monday for you!!
    Miele print part numbers on all their spares
    you got the pcb with you?
    Found this posted on this site might be worth a go and cheaper?
    c.b.r.s.(leeds)
    unit 2b sunny bank mills
    84/85 town street
    farsley
    leeds
    ls28 5uj
    07949307385
    cbrsleeds@msn.com
    good cheap circuit board repairs
    and thousands of refurbished boards
    #299126
    clayside
    Re: Miele W827
    Motor module part no 4229779
    Electronic part no 4825452
    from 01235 233133
    clayside
    #299127
    S1MON
    Cheers chaps
