Miele W827 noisy
  • #102833
    Grommet3
    Machine sounds like a jack hammer when spinning and bits of rubber coming off the seal (quite a new seal so not perished). Put a new set of dampers on and no different. Bearing seems smooth when turning by hand. Any suggestions? TIA.
    #490678
    sounds terminal
    the drum is held up by a 3 legged spider
    https://shop.ukwhitegoods.co.uk/mhw57515205-lg-washing-machine-drum-spider
    this is one off an LG machine to give you an idea
    over time the legs corrode and if one fractures then on spin the drum twists and goes out of true and contacts the door rubber
    checked Miele site and the spider looks like part of the inner drum at about £500 ish
    Grommet3
    Hi Dave. Thanks for the response. What you say makes sense.
