Miele W828 rinse light flashing.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele W828 rinse light flashing.
Viewing 15 posts - 16 through 30 (of 30 total)
  • #352857
    Re: Miele W828 rinse light flashing.
    no probs m8 just making sure no offence meant
    farnell part number 163-7545 T6.3 amp
    if you not used farnell before register your c card as corperate card that gets you round the £20 min order
    if you have probs pm me your address and i will pop you 2 in the post
    Just to update. Returned with repaired board this afternoon and all now running well. Canufixit? You certainly can! :tup:
    Mike.
    Relay stock no. 6803830 at RS.
    #352859
    Good to hear your outcome mike 😀
    canufixit
    #352860
    Now that posting pics is so easy I’m having a whale of a time! 😀
    This is what the inside of the relay looked like:
    Mike.
    #352861
    washtec
    just for reference, here is one I did the other day
    #352862
    Muv
    i’ve just finished doing the exact same job on the EL200 board Replaced relay and fuse,usually cut the old parts open to have a look inside..not seen any as bad as that relay pictured on earlier post though!
    keithwilliams
    already done this repair with exact replacement components about six months ago. problem came back and yes both relay and fuse blown. ive repaired the board again as i now carry these parts. but the rinse light is still flashing.
    any ideas
    #352864
    Check for small voltage from tacho at conn. to board whilst revolving drum by hand. (Connection diagram tucked in there somewhere.) If you have signal and brushes are OK, then there is still a fault on board unless there is a problem in loom to motor. Assuming your repair is good, check motor triac etc.
    If it repeated the same self-destructive behaviour, machine almost sure to need new shocks (Europart do them cheapest last time I looked.)
    I’ve just broken a Miele with same board and motor due major spider failure. Drum was seized as a consequence. Not checked board or motor yet but look OK. Let me know if you want either for a fair price and I’ll get on with checking them.
    Mike.
    #352865
    keithwilliams
    hi mike
    thanks for the offer. as this machine is in a semi professional laundry (holiday complex) shes decided to replace it as it is getting on and has now lost faith.
    at my last visit i discovered that the fuse had blown again even though it had never actually worked.
    its a win win repair most of the time but on this occasion there must be some other factor involved. (motor checked out ok)
    keith
    #352866
    Muv
    Hi all
    I repair quite a few of the EL200 boards myself, but have now got a EL200C board to repair..
    On this board there is a extra relay underneath the one marked 6K1 in the picture a few posts up..
    (The usual one that the contacts weld together in)
    Anyone know what this is for?
    IP
    Hi all, I have a customer who has a Miele W842, with the typical rinse light flashing, I have replaced the brushes, and looked at the fuse and replaced it along with the relay. This normally does work and I have done a few of these but not this time, still doing the same I’m guessing there is another fault on the board anyone able to help me out with this one?
    Thanks Ian
    #352868
    you will have to trace the motor circuit. cant think from memory but therer may be more than 1 relay involved. check motor make sure you have all connections would not be the first time i did not get the brushes to connect properly
    put a picture of both sides of the board on here may help
    IP
    Thank you Dave,
    I have checked the brushes to make sure they are contacting as I have had the same issue once that took me about 10-15mins to find out after replacing them so now I test all of them when I replace them.
    Here is both sides of the board as requested no obvious signs of failure
    Ian
    #352870
    are you reading the motor drom the pcb arm , field and tacho ?
    IP
    I checked the connections from the pins on the motor, I didn’t think about testing the wire harnis to the board mind, I was having one of them days where the day just didn’t go right, and I got to the point where I’d checked the usual fail points and now I’m here lol
