Miele W833
  • #28322
    goosegreen
    Called the other day to the above, And found it to be a blocked pump but could not remove the inner part of the filter, Managed to clear the the lump of bath mat by taking the pump motor off the pump body but think I have damaged the inner part of the filter by trying to knock it out from the inside. Any one know the part no for the inner part of the filter, The assembly is made up of the outer threaded handle, then a spring pushing against another disk. then the main filter? In 15 years this only the 3rd Miele I have come across, So not very experienced on the brand 😕
    Cheers Goose
    #217875
    clayside
    Re: Miele W833
    Comes as a unit part no 3017362 £19.40 or looking at it from front to back screw front 3655190 £5.70, spring 2854480£4.82, lid 2840261 £3.88, insert 3651450 £4.82, inner lid 2841702 £2.53 all plus VAT
    I norm fit assy. regards clayside
    #217876
    goosegreen
    Re: Miele W833
    Thanks for that clayside I think I will order the compleat set
    Goose
