Miele W842 Premier Novo – Excessive vibration
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Miele W842 Premier Novo – Excessive vibration
  • #57673
    paul25
    Hello folks
    I have a Miele W842 washer that’s about 10 years old and recently noticed that on the spin cycle it is making a lot of noise and vibration. The machine is never filled with too heavy or too light loads. When the drum is turning during normal operation (not just on spin cycle) it also seems to be bouncing up and down a bit more than I can remember.
    I intend to pull it out from under the counter and take off the lid, can anyone suggest what I need to look for and what the problem may be.
    Thanks in advance
    Paul
    #331925
    Re: Miele W842 Premier Novo – Excessive vibration
    Re adjust the feet before you touch anything else.
    It’ll most likelly be either need adjusting or touching something.
    Bryan
    #331926
    paul25
    r600a wrote:Re adjust the feet before you touch anything else.
    Bryan
    Thanks for the quick reply 8)
    I’ll go and do that now.
    Paul
    #331927
    paul25
    I’ve checked the feet according to the handbook and used a spirit level. I didn’t need to make any adjustments, there is no movement and it is level.
    Do you think it may be the suspension?
    Paul
    #331928
    Seamy
    Turn drum with your hand when the doors open, if theres any roughness in the movement it may suggest bearing trouble. Bearings & suspension are not known to be that problematic to be honest unless it has gotten excessive use.
    #331929
    paul25
    I’ve turned the drum and it rotates smoothly, but I did notice it moves back and forth quite easily. A fairly light push to the back of the drum can make it rock back and forth and it make a “clonk” sound when the drum reaches the front.
    The machine is used on average about once a day, sometimes twice, for a family of four for the last ten years. I don’t know if that is considered excessive?
    Paul
    #331930
    paul25
    Update
    I called the Miele helpline and explained the symptoms and the technical people thought the shocks were at fault.
    I ordered some Europart replacement shocks and carefully laid the washer on its side and swapped them. The old ones looked to have leaked some oil and grease down the struts to the mountings.
    The washer spins much quieter now without the awful hammering/drumming noise, but I still think it isn’t quite right. Should I consider changing the mounting springs? Does anyone have any suggestions?
    Paul
    #331931
    odom
    Have you checked the counterweights are attached securely?
    #331932
    paul25
    Hello odom
    Sorry about the delay in replying.
    I’ve checked the weights and they are all secure. I’ve looked around the rest of the machine and all fixings and fasteners are tightly secured.
    The machine is running a lot better now that the shocks were replaced it’s not quite as good as it was. Is it possible the vibration may have damaged something?
    Paul
