Miele W842 Washer
  • #41650
    mike100
    Rinse light flashes when motor action required and no turn.
    Had motor out and brushes only half worn.
    Any cheap ideas or is it likely to be module.
    Mike
    #270864
    Seamy
    Re: Miele W842 Washer
    Check cable connections to motor & board, board fault can also give this (F4) which means no signal received from tacho. There is a thermal cut-out in motor windings which can go open circuit also worth a check.
    #270865
    mike100
    Thanks Seamy will go back and give it a try.
    Mike
