Re: Miele w844
Yeah its a drive failure for sure, on the new machines with 3 phase motors there is an in built cut out in the motor and these can give trouble, or if theres a frequency converter board, check that the fuse on board has not blown, there is a visible fuse and there is a “track fuse” which is just a very thin track of solder on board. I’ve seen that blown.
💡 BE CAREFUL while working with frequency converter boards there is a Voltage of 400 volts stored in capacitor long after power is switched off. Gives a nasty kick!
