miele w844
  • #29539
    wilf
    looked at this machine when first tried it filled ok and went onto wash second attempt on any program valve pulses then stops machine “check inlet light” flashes. no blockages in chamber or hose cannot hear click on pressure switch although if its a board mounted device I dont suppose I would, would I? as the valve has worked I suspect a board fault but which one? any Miele bods out there that can help?
    wilf
    #223541
    trotter
    Re: miele w844
    Wilf I am not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure but I THINK it may be the small cut out on the board have you had any motor action since you have been trying to get the machine started?
    #223542
    Seamy
    Re: miele w844
    If 10mm of water is not detected in 30secs “check inlet” is displayed, if no further increase is detected in next 30 sec’s drain pump is started.
    You can change this time from 60s to 255s in the programmable functions if theres bad water pressure.
    Check the solenoid valves, i think its a 3way cold water solenoid with a water protection system in built ( float switch in base ).
    Check filters are’nt blocked at water intake & also check pressure vessel for blockages too…
