miele w844
  • #34934
    domesticbliss
    Fills then rinse light flashes and machine empties.
    Rinse light flashes on all cycles..looks like it may be the module side of the main prog board..no motor turn at all..motor appears ok though.
    Any ideas?….
    I suspect it is the main board but due to cost would like to know if anyone else has had a similar fault.
    Many thanks in advance.
    Paul
    #244505
    philfish
    Re: miele w844
    rinses light flashing on miele’s usually indicates drive fault must recieve signal back from tacho within 1.5s or it starts to flash! double check motor probably carbons
    #244506
    domesticbliss
    Re: miele w844
    Thanks for your input Phil, I thought it was linked to motor as manually spinning the drum stops the lights flashing…I have a few spare motors and have tried them along with checking the brushes which just about confirms the module board faulty..QER £49..unless you know of a better source….
    Paul
    #244507
    Seamy
    Re: miele w844
    Likely motor brushes worn away?
    Did you take end off motor & check them?
    This can be done without removing the motor.
    I’ve come across faulty boards but i’d check brushes & cable loom motor plug first
    Part num’ – brushes:- 4297411
    #244508
    domesticbliss
    Re: miele w844
    Thanks for that Seamy..I`ll check more closely and post an update.
    Paul
    #244509
    domesticbliss
    Re: miele w844
    Finally found time to go back to the Miele..motor is defenitely ok along with the motor plugs and loom..buzzed each one through!
    Looks like i`m back to the EL200-D module board….anyone got any good sources of repair or replacement?..Miele quote silly money.
    Paul
    #244510
    Seamy
    Re: miele w844
    Try this link, this Dutch guy offers a postal repair service on a lot of Miele boards….
    http://members.home.nl/peter.stuart/miele/en/index.html
    #244511
    domesticbliss
    Re: miele w844
    Thanks for that seamy, the link will defenitely come in handy. I`ve emailed him to see if he covers the w844 range as his site says he doesn`t….any other possible sources?
    Paul
