Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Miele W863 “rinse light flashing”
- This topic has 11 replies, 5 voices, and was last updated 19 years, 6 months ago by
maltheviking.
September 15, 2006 at 5:28 pm #20888
maltheviking
ParticipantHi All
I have one of these with a fault. 😥 The machine fills ok then the “rinse” light starts flashing. Put the prog.to spin and it does the same after a couple of secs. Pump works fine. I have checked all the functional parts including associated wiring, all seems fine. Any help would be appreciated. and how do you access the diagnostics on a W863?
Mal
September 15, 2006 at 7:09 pm #188670gegsy
ParticipantRe: Miele W863 “rinse light flashing”
Havent got that info to hand but looking at the WS5425 service manual you may be looking at a motor fault eg brushes,drive etcGreg
September 15, 2006 at 8:58 pm #188671maltheviking
Hi Greg
Yep the motor was my first thought “so I whipped it out” :rolls: after checking it out via the loom. Brushes/ armature were fine, continuity ok
BUT I still have a niggling doubt about it under power 😕 as I hear a relay kick in just before the alarm, could also be a traic. I need the diagnostics to confirm especially at the price of the motors and boards 😯
September 15, 2006 at 9:05 pm #188672gegsy
I have had an amp tag burn out on the motor plug and where the front panel hinges, the loom had damage, look carefully 😉Greg
September 16, 2006 at 8:35 am #188673Seamy
Sent you a PM, be careful when checking drive electronics as board holds up to 400v for a time even after its disconnected. There is a temperature limiter built in to the motor. Desired motor winding at room temperature should be 7 ohms. Check motor tacho, turn motor by hand & you should generate 1 – 3 volts AC. Check tacho against motor frame there should be no continuity, check also between motor plug & frame, also no continuity. Most problems i have are brushes, clean armature & make sure brushes are touching ok, there is a holding device on these as in hotpoint brushes which may prevent them from moving in onto armature. The motor brush holder can all be removed from front of machine without taking complete motor off. Best of luck.
September 16, 2006 at 4:37 pm #188674maltheviking
Thanks for everything Seamy. much apreciated. 😉 I forgot to mention customer complained about hearing a “thud” just before alarm started, I will double check the tacho to see what has falled apart ❗
Mal
September 18, 2006 at 8:55 am #188675hf
Has anyone done a pro series miele with the first rinse light flashing i had one the other day but it had an inverter board and induction motor. Motor seemed fine but i didnt want to risk buying board on the chance, they had been quoted “about” £600 my miele……
September 18, 2006 at 9:01 am #188676Seamy
HF, please post details, model number would be a great advantage, i’ve sent you a PM.
June 18, 2010 at 2:23 pm #188677robbra
Ok Ok it’s an old thread.
I have one of these Nr.00/49269447 No motor action.
Rinse light flashing. Checked brushes for continuity, fine, but didn’t drag the motor out 😳
Also the inlet check light on although plenty of pressure and fills fast.
Questions
1, is this likely to be the brushes just worn too much? Can they be changed with the motor in situ? What’s the part no. as connect don’t list this model?
1, is the inlet check probably a blocked pressure pot or are the two problems together a bit more sinister?
Thanks in advance
RobJune 20, 2010 at 5:02 pm #188678robbra
Anyone???
I am loath to chance buying these bushes (£40.65 each..Connect) £28 gen pair off ebay but if no answers then I’ll take a chance.
Rob
PS. Customer says the check inlet has always been on since newJune 20, 2010 at 7:37 pm #188679maltheviking
robbra wrote:Anyone???
Rob
PS. Customer says the check inlet has always been on since newHi Rob
I was you I would get the motor out (bit of a PITA) and check for circuits via the motor plug, all terminals should be in circuit. Not to bad to dismantle once it is out so you can check the armature etc.
good luck
MalJune 21, 2010 at 6:48 am #188680robbra
Thanks Mal,
I tested continuity on the motor and all were ok, even the brushes. I think it must come out to check the brushes visually. I was stuck for time on the first visit.
Rob -
