Called out to this machine yesterday. No motor action and rinse light flashing on all cycles. Checked carbons, worn but still about 1/2″ left. Checked pressure chamber, fine. Checked wiring continuity, fine. Tacho seems fine but obviously being Miele no idea of knowing if resistance is right. Machine & motor both megger okay.
There are some slight burn marks on the power board, cleaned it up but still the same fault. Is there anything else that can cause this fault? Miele want the normal arm and a leg for a new one and it’s a lot of money to spend on a hunch.
Cheers.
Chris
