Miele W865 Washing machine. Rinse flashing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Miele W865 Washing machine. Rinse flashing
  • #75357
    Latham63
    Flashing rinse light suggests a motor fault I think.There is no motor action. Checked brushes,ok.There is continuity on all pairs of connectors.4 in all. No earth leaks,tested with mega.Hope its not a pcb fault??
    #394652
    Muv
    Re: Miele W865 Washing machine. Rinse flashing
    Usually a PCB fault.. You need to check the motor direction relay 6K1 and alsomthe associated radial fuse…
    If you want i can check/repair it for you… Done loads of them
    Latham63
    Thanks Martin.A repair/check would be good.What address shall I send it to?
    #394654
    Muv
    Have sent you details via PM, let me know if you havent recieved, as i sometimes get problems
