I have a problem with this machine, where the PC light starts to flash and the machine stops. This is after it has tried to fill for a minute or so. It is not filling properly and I suspect that the fill/ aqua stop valve is faulty, Can’t find anything in the fault code list. Can anyone help please? Steve
Sounds like it could be a water inlet problem! 😉
I’d check water inlet hose, valves, filter in inlet.
Also look if theres been a leak & activated float switch if one is fitted in machine base.
Hello Seamy, thanks for the reply. Yes, checked all that. No float switch fitted. The flow rate through the inlet valve seems to be the prob so will change that. Cheers. Steve.
