Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › miele w916 spins ok with no load but with load acts unbalanc
- This topic has 6 replies, 3 voices, and was last updated 9 years, 4 months ago by
paulg2906.
December 8, 2016 at 9:09 pm #90066
paulg2906
Participantbeen to a miele w916 washer today found the rinse light flashing 1+2 replaced carbon brush set, put it back together spins and washes perfect. but with a load in the drum it wont do a revolution of the drum it just judders back and forth like its unbalanced
is there a balance sensor on this machine its 26 years old the customer is insistant it is repaired !!
can anyone shed any light please thanks :eeek:December 8, 2016 at 10:14 pm #443455electrofix
ModeratorRe: miele w916 spins ok with no load but with load acts unba
sounds like armature failure
December 8, 2016 at 11:17 pm #443456eastlmark
were the brushes worn down? Is this the type with the brushes in a removable module on the back of the motor? If so have the pins located correctly into their sockets in the coils? Don’t want to state the obvious but is the belt tight?
December 9, 2016 at 7:15 am #443457paulg2906
ParticipantRe: miele w916 spins ok with no load but with load acts unba
yes the brushes where dead. The module that holds the brushes was on correct i removed it three times every time i refitted it it would spin without a load but not with.
The belt was also tight no movement after all those years
i looked at the armeture there was no pieces missing !!
THanks for the input though i was still there at 730 pm last night !!!December 9, 2016 at 9:05 am #443458electrofix
if its the armature
it does not need a piece missing just a damaged coil to oscillate instead of turn
with no load motor will skip the faulty segment no problem but under load it wontDave
December 9, 2016 at 11:14 am #443459paulg2906
Hi and thanks have now spoken with the customer it now works on every cycle except delicates and heavy loads ????
He wants to try a second hand module what are your thoughts ????? Thanks againDecember 9, 2016 at 11:23 am #443460paulg2906
I’m with you though Dave your answer sound spot on
