then maybe its the aquastop valve gone? Be careful with Miele valves though as some are 125 volt coils. Would suggest connecting a normal fill hose to the inlet valve in the machine but you have to leave the aquastop valve connected electrically to prove if its works or not, if it then fills fine then its the aquastop valve at fault and even more £££
