Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Miele W919 water wont flow though inlet pipe
- This topic has 8 replies, 3 voices, and was last updated 18 years, 7 months ago by
Big_C.
September 5, 2007 at 10:16 pm #30328
Big_C
ParticipantWater will not feed into machine so i pulled apart and checked all pipes and found prob with inlet pipe disconnect from machine and tap to see if clear, the pipe wont allow water into the machine but will let it out if u blow though pipe but wont flow into machine only flow 1 way through the pipe and thats the wrong way? 🙁
September 5, 2007 at 11:52 pm #226766Penguin45
ParticipantRe: Miele W919 water wont flow though inlet pipe
Got any resistance through the solenoid coil?
Power off…………..
September 6, 2007 at 5:59 pm #226767Big_C
It wont let water thought inlet pipe with power on or off i disconnected pipe and all u can do is blow water out of pipe but not through?it has a grey box at point where it screws on to tap!I dont no what this is maybe valve of some kind i dont no!Also i cant find anywhere to buy a new miele inlet pipe the same as i have?Any help would be good thanks
September 6, 2007 at 11:16 pm #226768philfish
Hi has already said you need to test the inlet valve which is the grey box that you described but that box is a sealed unit so you will have to trace the wires into the machine if i remember correctly they are on a push fit type connector and do a contiuity test from there remember power off first!!! And make sure that your water supply is ok to machine. I got a nasty feeling those inlet valves are £100ish and only available from miele unless someone else nows where to get them cheaper!
September 7, 2007 at 7:55 pm #226769Big_C
how do i do a contiuity test ?
September 7, 2007 at 8:13 pm #226770Penguin45
You need a test meter to check for resistance. The component to be tested need to be separated from the circuit to avoid back-readings. An inlet valve will typically give a reading in kOhms.
Needless to say, mains power must be off at all times.
If you are unsure how to proceed, you must seek professional help.
Penguin45.September 7, 2007 at 9:13 pm #226771Big_C
Hi thanks for ur help!What result will i be looking for?
September 7, 2007 at 9:18 pm #226772Penguin45
Penguin45 wrote:An inlet valve will typically give a reading in kOhms
September 8, 2007 at 4:10 pm #226773Big_C
I done test and metre read 10koms is this normal?
