Re: Miele W919 WPS knocking noise during rinse cycle
Could be a loose motor mounting bolt.
Heater element has come loose from its holding bracket,the element may be visible through the bottom section of the inner drum holes.
Other things worth checking
Pump filter may be clogged
Pump impeller may be loose on its shaft, check for side to side movement in the shaft as well..
Drum spider support arms
One may have a crack in it…
Lots of things it could be,but narrowing it down may not be easy.
Let us know your findings
Sent from my iPhone using Tapatalk
