miele W937
  • #62327
    domesticbliss
    Hi, mean beastie of a machine but has the `rinse 3` lamp flashing..machine will only do a drain and spin.. not seen this one before. any ideas would be more than welcome.
    By the way LOVE the new site and layout, well done.
    Paul
    #349691
    Re: miele W937
    Isn’t rinse light flashing no feedback from tacho = brushes usually?
    Mike.
    #349692
    steve1
    Re: miele W937
    faulty control module
    #349693
    domesticbliss
    Re: miele W937
    Hi and thanks for your input. usually flashing rinse light does point to either/ and direction control relay on module board which also blows the 6.3A fuse on same board, preventing the motor from working.
    However, this machine spins fine, brushes are ok. there are TWO rinse lights, rinse 1 and 2 and a rinse 3 lamp, which is the one flashing..NO water is taken in on any cycle but will drain and spin…
    any more input would be appreciated.
    Paul
    #349694
    steve1
    Re: miele W937
    hi paul
    I have had this problem before, in my case it was the module board,put in a replacement board, all ok
    steve
    #349695
    domesticbliss
    Re: miele W937
    Thanks steve, do you happen to know which part of the board failed? is it temp related?
