The machine is completely dead with no display or signs of life at all. I have a supply to the on/off switch/PCB. From the on/off switch/PCB, there are two sets of tracks that look to be switched. One pair of leads from these tracks goes to the PCB mounted in the door base. The other I think, goes to the facia PCB. I am getting 240 through to one track, and a neutral supply to the other three. Also the door switch is supplied from the on/off PCB. I suspect I am losing the second supply inside the on/off switch, but am not sure if that is the way it works. I am convinced that the problem is either in the on/off PCB, or in the door switch. However, even with a faulty door switch, there should be some sign of life I think. Any ideas anyone please? Cheers. Steve.
