Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Miele Washing machine help please!
- This topic has 10 replies, 2 voices, and was last updated 4 years, 8 months ago by
Dave1962.
July 27, 2021 at 4:42 pm #99858
Dave1962
ParticipantMiele Honeycomb W2240
This machine has been very good, but now doesn’t always drain.
I have checked and cleared all drain tubes and the pump appears to be working (although louder (at times) than it was).
Sometimes runs through a programme with no problems, sometimes stops on the 2nd drain.
Is this a mother board problem or pump?
Thanks,
DaveJuly 27, 2021 at 5:35 pm #478190electrofix
Moderatorthere is a thin pipe coming off the pump chamber. it goes to the top of the machine and splits through a Y peice. remove and check this tube is clear as had a few pump out problems due to this
July 27, 2021 at 5:47 pm #478191Dave1962
ParticipantIs that the pressure switch?
I have checked the tube and it is clear, the pressure switch itself looks like its on the motherboard so not replaceable on its own!
ThanksJuly 27, 2021 at 5:50 pm #478192electrofix
Moderatorno its a vent pipe to get air out of the pump
see pic part 21Dave
August 8, 2021 at 3:25 pm #478193Dave1962
ParticipantHi Dave, sorry for the late reply, ( I have been unwell but now ok and sorted it) and thanks.
It looks to have fixed the problem, i found most of the problem in the plastic pipe on the housing that the rubber pipe slides onto.
I have a problem with unbalance loads (towels mainly) in that the drum bounces around and hits the brake non return valve (some call it the water level air chamber) so hard that it breaks a hole in it and i now need to replace that! (aaaargh!)
Is this a common problem?August 8, 2021 at 3:49 pm #478194electrofix
Moderatornever had the air chamber break
but if it bounces a lot consider and check the dampers. Non gen sets are quite cheap
https://shop.ukwhitegoods.co.uk/43ml01-miele-washing-machine-damper-setany other gen only parts go direct ti Miele as its often cheaper
August 8, 2021 at 4:47 pm #478195Dave1962
ParticipantThanks again, i will have a look.
would you do the springs at the top at the same time?August 8, 2021 at 7:03 pm #478196electrofix
Moderatorno just the shock as springs often snap when they break so will not need doing
August 12, 2021 at 6:00 pm #478197Dave1962
ParticipantHave cleared out the pump vent pipe, and it was gunked up as was the plastic piece it slides onto on the pump,
Replaced the dampers and hooked the springs up a notch on the bracket.
3 washes done and looking good.
Thank you very much for the bits of advice, shame i cant rate your help anywhere!
Thanks again,
DaveAugust 18, 2021 at 7:58 pm #478198Dave1962
ParticipantAnd then failed on the next!
I have now replaced the pump which has made no difference and also cleared the drum end of the sump tube where the ball is, again no difference, it is still randomly not draining , sometimes it will go through a wash no problem!
I have just done a ‘quickie’ rinse and spin and i drained it manually when i heard the pump start each time it needed to drain and that got it through the programme.
I could see the pump spinning but it wasnt draining, BUT i have replaced the black rubber tube from the pump to the air chamber which is new too, and i have made sure the external outlet tube is free running, so it is still a complete mystery!!
i think the pump was spinning clockwise and then next time anti clockwise which is wierd, obviously it was too fast to see but from the way the water was moving ( i had the filter cover off by this time!)
I will now swap the control board as there may be a ‘dry joint’ on there which would explain the randomness of this annoying problem!August 18, 2021 at 8:07 pm #478199electrofix
Moderatorif the pump is running the board has done its job
its can only be the pump, a blockage or air locked
